Pool Math dataset incomplete for "Intex" SWGs.
packetfire
Active member
Sep 7, 2018
27
Jersey Shore
The only pool-math listed SWG under "Intex" shows the "Krystal Clear" and lists it at .63 lbs / 24 hrs.'
There are at least 2 "Krystal Clear" models, with model numbers on the front of these units.
The "Model ECO6110" is the 0.63 lbs / 24 hrs, while the "Model ECO5110" is 0.24 lbs /24 hrs. Big difference.
Mdragger88
3,004
Hernando, Ms
Intex Krystal Clear
U can just put your value in pool setup since u know it - the one listed in poolmath is the old version I believe before they came out with 2 different choices. For instance i ran 2 (a big one & a little one) so I combined the lbs/day & used that # in my set up in the settings.
