pool math app SWG calculation
H-12 1/2 Mike
215
Highland Village, TX
I run my pump at 2000rpm with the SWG @ 40%. My question is: Does the difference between a pump speed of 2000 rpm vs 3200 rpm affect the output of the SWG? The reason I ask is that the app recommends I run the pump for 4.25 hrs to maintain the chlorine level. What rpm is the SWG output calculated at in the app or does it matter?
Mike, SWG gives same CL output regardless of pump speed and water flow.
Any RPM sufficient to close the flow switch so the SWG operates and does not show LOW FLOW.
