Pool Liner Floating!! Help Please
tangte
16
Tallahassee
I live in north Florida. It has been raining really bad in the last few days and my liner has been floating since last night. I attached some pictures. My liner came off the wall, all the way around. And there seems a lot of water behind the liner. Today has been very sunny. And I just let the pool sit there for the whole day. When I came home from work in the evening, the water level came down about 1 inch. I assume that was cause by the ground water receding, or there may be a leak (hopefully not). However, there still seems a lot water behind the liner. Does it take a long time for that water to go away by itself (or will it ever go away)? Or should I find a pool professional to pump it out ASAP? Thanks for your help in advance!
:wave: Welcome to TFP!!!
It should be able to drain out the same way it came in.
Do you have a well point near the pool to pump ground water away? If you do, you could get a sump pump running from there.
Thanks for your reply. The liner went back to position after about 2 days. The wall looks ok. A lot of new wrinkles developed at the bottom. I actually had small wrinkles developed at the bottom all the time. For a long time I thought it was caused by pool chemicals. Now I realized, my liner may have been floating from time to time, after a heavy rain.
A small portion of the liner came out of the track. I was able to put it back in with hot water.... This is a nightmare, but not the end of the world. Hope this post helps other people not to get panic when the liner floats.
