Hey gang, long time lurker, first time poster.
Wondering if I could pick your brain about the conduit running to the pool light? My light filled with water a few months back and I'm just now getting around to fixing it. I tied off string to the end of the wiring, took the light housing off and out... wire and string (25 feet) pulled out ok. Wasn't super easy, but came through with no problems. Tied the string to the end of the new light wire to pull back through and the string snapped. A few curse words and a thrown ball of string later, I pulled out the 200 foot snake line.
Starting at the gfci end, I started fishing the line through, hoping to get through to the niche. Yeah, not so much. About 18 feet in it's like I hit a brick wall. Absolutely no movement past that point.
I tried going the other way, starting at the niche and ending at the gfci - about 4 feet in I no longer can push any further.
Frustrated, I go back to the gfci end and try again. Nothing. Everything I seem to do fails.
I pull the air compressor hose out and blow through the line, and the niche is bubbling like a kid blowing through a straw into his milk. Good sign, since it doesn't appear that the line is blocked. I pour a little water down the hole and blow again - bubbles (and no debris). So tells me that the line is still clear and hasn't been breached or broken.
That said, what the heck could be the reason why I'm not able to push my snake past the 18 foot mark on one end or the 4 foot mark on the other? Is there a severe turn in the pipe that is preventing me from going through? Anyone ever have a similar issue?
