Is there something, like a plug or stopper, that should be in the hole where the pool light cable is coming out from?
Did you see the pics I posted? Does anything look off to you in the pics? Or is it impossible to tell where the leak is with pics alone?If the leak is in the niche (cavity) itself, there are some band-aid fixes. There is a plug that can be pressed into the conduit opening for the wiring, while others may use a flexible sealant product if the leak is going into that conduit hole. You do not want to epoxy that tiny conduit hole in the back of the niche. Now if the niche shell itself is cracked somewhere in the back near the conduit opening, you can epoxy that crack since ti won't interfere with the wiring later. Chances are in either scenario the leak may reappear if the ground continues to settle.
Now if the leak is around the sealing ring between the light and pool linter/shell, that could require lowering the water level significantly to replace the ring/gasket. If that's the case, many owners tend to wait until it's time to replace the liner and do both things at once. Perhaps @jimmythegreek can confirm next time he gets online.
Pool light sealing ring replacement
So I have a pool light that the sealing ring on the niche has corroded away. I had a leak in the pool and the guy indicated I have a leak at the niche seal and recommended replacing the ring and gasket. I am wondering the best way to do this? I am a couple years out from a new liner. I have a...www.troublefreepool.com
I did, but those thumbnail views are a bit small and I can't tell for sure.Did you see the pics I posted? Does anything look off to you in the pics? Or is it impossible to tell where the leak is with pics alone?
It's open and water flows into that conduit with the wiring. But if the conduit pigtail is cracked deep in there where it bends (which you can't see), water will leak as it goes out that crack. A dye test will pull dye into that conduit if that's the case. I'm not familiar with that product you found on Amazon, but it's flexible and worth a shot. If you Google Pool light conduit plug you might find the aftermarket plug used for the same purpose. If I find it I'll post back.Is the conduit hole always supposed to be plugged or is it okay that is was left open like ours was?
Okay another dumb question, but why would it be odd for the pump basket to hold prime if all the lines are plugged? I thought that was a good thing so now I am concerned about that :/ Should we have relieved pressure before plugging the lines? All we did was turn the pump off and then plug the lines. And the leak guy said he also tested all of our lines underground (pipes) and that they were all good. (We removed the plugs before the leak guy came and filled the pool back up).Well, since the leak detection tech confirmed the light is the source of the leak, you're almost to a point where you have to decide if you want to just get the liner & light replaced at once. If the tech didn't find a leak in the light, the only other place I would've gone back to was the main drain because after re-reading your thread, I found it odd that in a couple posts you stated everything was plugged but the pump remained primed. So I was wondering is water was leaking somewhere out of the drain line. But again, if a tech confirmed the light, it's hard to argue. Maybe you can try to speak to the tech to get more details about the exact location in/around the light and ask why the dye test didn't reveal anything.
Maybe we misunderstood one another. I thought you were somehow referring to keeping prime while the pump was ON, which is why I mentioned the drain thing. But if all you are saying is that once you plugged everything (all lines), the pump pot remained full when pump was OFF, that's good. That just means all the plumbing lines seem to be leak-free. Think of pushing a straw into a glass of water and putting your finger over the top. Then you can lift the straw up out of the glass and the water will stay in the straw UNTIL you take your finger off. Same thing here. The pump pot stayed full because the plumbing is intact, but remember you can still have leaks in other places like a light, steps, liner, etc that have nothing to do with the plumbing.why would it be odd for the pump basket to hold prime if all the lines are plugged?
IMO, yes. During the liner install. Perhaps @Poolbreh can confirm for us.The conduit is good and leak free, the dye test showed the bottom screws are leaking at the plastic ring.”
Soooo, is this something that should be able to be easily repaired when our liner is replaced?
Hello everyone!IMO, yes. During the liner install. Perhaps @Poolbreh can confirm for us.
