Hi. I have a 15000 gal in ground salt water pool. I recently noticed that the salt level was falling. I turned off the auto fill and the salt level stabilized and I noticed that the water level fell several inches over a few weeks. Once the water level was nearly down to the bottom of the skimmer inlet, it stopped falling further. The skimmer still has water in it and appears to be functional, as the water level is about 1/2 inch above the bottom of the inlet. I also noticed the silver travertine surrounding the skimmer looks a little darker than the rest of the deck. Putting all this together, I'm thinking there is likely a leak coming from the skimmer between the height of the normal pool water level and the height it is presently at. Upon inspecting the skimmer visually. I do not see any obvious cracks.
I'm not sure if my analysis of the situation is correct but I'd rather not pay for leak detection service if the source of the leak is obvious. Any thoughts on how to proceed at this point?
