The water level under the winter cover started to drop this spring then stopped with about 1ft left in the pool. I pulled the cover this weekend and found the liner had shrunk and was brittle (it was very cheap and was replaced 5 years ago. I then started to remove the liner and found a decent amount of rust on the walls. I also found a small dent right under one of the top rails but i suspect that is from someone standing on the rail. I'm not sure what direction to head on this.
Can the walls be saved if the are sanded, primed and painted? (the rust can be brushed off and the metal doesn't feel pitted
If the walls can be saved where should I get a new liner? What Mil?
I have always wondered about water splashing above the liner bead then getting behind it where the bead tracks join is this a legit concern?
I had a pad under the liner should I save it or replace it?
With the bottoms of my walls having a plastic riser I don't think I would be able to use a foam cove should I just stick with the sand?
Thank You,
Nathan
http://s942.photobucket.com/user/nathanc03/library/pool2018
Thank You,
Nathan
