I posted a few days ago about a steady drip that was coming out of our pool heater that was causing us to lose 1/2 inch of water a day. A pool pro came over yesterday and replaced some switch that caused the drip to stop. This morning, I went out to turn on the pump and check the pool and we had lost over a half inch overnight again, even though the pump wasn’t running all night. The puddles of water around the heater are larger than they were last night when I turned the pump off and it didn’t rain overnight. I see no evidence of any dripping when the pump is on or off. If we have another leak in the heater, could it cause water to drip out when the pump isn’t running? There is also a lot of water on the ground near the salt water generator cell. Could that be leaking? Could there be a pinhole leak in one of the pipes that goes into/out of the pump and/or heater that would leak when the pump is off? There was so much water around the heater when the pool pro came to fix the heater yesterday that he couldn’t tell for certain if anything else was leaking or not. He told me to wait until everything dries out to see if it is still leaking. It appears that it is never going to dry out since it is still leaking. Since we do not use the heater, should we get a bypass installed for the heater and see if that stops the leak? Finances are tight right now so I just want to get this leak stopped as inexpensively as possible.
