Buddies and myself installed my pool yesterday. Terrible weather (50s and windy) but did it anyway. The liner did not go on straight nor did we vacuum behind in (one of pool buddies who did his own said no need). I noticed air between vinyl and pool wall. As I added water, it got worse. Quickly started pulling the straight sides in. Pool is sitting on 4" blocks all around. Can't tell but they are buried 3" with 1" above ground for foam board. We leveled first block and leveled all the way around (always leveling with previous 2 blocks using a long level). In the end, we were about 1/2" off.
What are my options? I was thinking of draining the water and resetting the liner. I know I need to get seem higher up the cove. Could this be the problem or is it something else?
