I'm in the midst of designing a new construction underground pool.
It is a 17k gallon play pool.
Location is Phoenix, AZ.
We have very hard water in Phoenix to the degree that I get super itchy and irritated skin in a matter of days if the salt is low in the house soft water system.
Pool will have a SWG.
Will be pebbletec.
I have plumbed hard water and soft water on the side of the house for the purposes of replacing the water that evaporates from the pool. I figured I would use soft water for the float pool fill valve and hard water for any time I need to fill the pool originally and after any potential future drainings.
Should I use soft water for the daily replenishing of pool water?
Should I instead use some type of valve so that I can have a mixture of hard and soft or even change from one to the other?
Should I just use hard and then use salt directly into the pool on an as-needed basis?
Any help is much appreciated.
Will be pebbletec.
