15.08.070 Perimeter swimming pool enclosures
A. Notwithstanding any other provision of this Code, all swimming pools shall be
entirely enclosed by buildings, or fences or walls not less than five nor more than six
feet in height. All such enclosures shall be so constructed as to prohibit the penetration
of a solid object that measures four inches in its least dimension. Hotels and motels
which offer a swimming pool as an accommodation to their guests shall be exempt
from the above enclosure requirement so long as they provide 24-hour surveillance of
the entire area of the pool constantly monitored by video viewer screen and an alarm
system covering the entire area of the pool, constantly monitored by an on-duty
employee required to be awake during the entire monitoring period. The operation of
the surveillance system and monitoring shall be subject to inspection at any time by
the city and in the event that the city manager at any time finds that the surveillance
and monitoring required fails to meet the standards set forth herein for the exemption,
this exemption shall be withdrawn upon a 10-day written notice and the enclosure
required shall be constructed.
B. Other than doors from a single-family home, all doors and/or gates opening
directly into the pool area shall be equipped with a self-closing, self-latching device
designed to keep the door or gate securely closed at times when not in use. The
latching device shall be located not less than 60 inches above the adjoining ground
level, walks or levels. A gate which services a driveway shall not qualify as meeting the
requirements of a self-closing gate. In no case shall any gate have a width greater than
four feet unless specifically approved by the administrative authority.
C. Doors, gates, latches, and all other portions of the above enclosures shall be
maintained in good condition and shall at all times provide the protection for which
they are intended.
D. During the course of construction, a swimming pool shall be filled with water until
such time as final inspection has been made and the work approved by the building
department. The final inspection shall not be called for until all enclosures, including
the enclosure or other safety device required by Section 15.08.090, have been
provided, and all electrical and plumbing work has been completed except for finish
plastering. No pool shall receive a finish coat of plaster until the above inspection has
been made.
15.08.080 Swimming pool safety features-Single-family homes
A. Applicability. In order to prevent child access to swimming pools, any construction
of a new swimming pool at a private single-family home shall comply with this section.
B. Definitions. The following words as used in this section shall have the following
meaning:
"Alarms" means devices that make audible, continuous alarm sounds when any
door or window that permits access from the residence to the pool area that is
without any intervening enclosure is opened or is left ajar. Alarms may be battery
operated or may be connected to the electrical wiring of the building.
"Approved safety pool cover" means a manually or power-operated safety pool
cover that meets all of the performance standards of the American Society for
Testing and Materials (ASTM) in compliance with standard F1346-91 as may be
amended from time to time.
"Building official" means the building official of the city or his or her designee.
"Enclosure" means a fence, wall, or other barrier that isolates a swimming pool
from access to the home.
"Public swimming pool" means a swimming pool operated for the use of the
general public with or without charge, or for the use of the members and guests of
a private club. Public swimming pool does not include a swimming pool located on
the grounds of a private single-family home.
"Swimming pool" or "pool" means any structure intended for swimming or
recreational bathing that contains water over 18 inches deep. Swimming pool or
pool includes in-ground and above-ground structures and includes, but it not
limited to, hot tubs, spas, portable spas and nonportable wading pool.
C. Whenever a construction permit is issued for construction of a new swimming pool
at a private, single-family home, it shall be equipped with at least one of the following
safety features:
1. The pool shall be isolated from access to a home by an enclosure that meets
the requirements of subsection E of this section;
2. If approved by the building official, one of the safety features set forth in
subsection (D)(1), (2), (3) or (4) of this section.
D. Whenever a construction permit is issued for construction of a new swimming pool
at a private, single-family home and where a wall of a Group R, Division 3 Occupancy
of dwelling unit serves as part of the barrier and contains door openings between the
dwelling unit and the outdoor swimming pool that provide direct access to the pool, an
enclosure meeting the requirements of subsection (C)( 1) of this section shall be
provided. If approved by the building official, one of the following safety features may
be substituted:
1. Self-closing and self-latching devices installed on all doors with direct access
to the pool with the release mechanism located a minimum of 60 inches (1372
mm) above the floor;
2. An alarm installed on all doors with direct access to the pool. The alarm shall
sound continuously for a minimum of 30 seconds within seven seconds after the
door and its screen, if present, are opened, and be capable of providing a sound
pressure level of not less than 85 dB(A) when measured indoors at 10 feet (3048
mm). The alarm shall automatically reset under all conditions. The alarm system
shall be equipped with a manual means, such as a touchpad or switch, to
temporarily deactivate the alarm for a single opening. Such deactivation shall last
no longer than 15 seconds. The deactivation switch shall be located at least 60
inches (1372 mm) above the threshold of the door;
3. An approved safety pool cover;
4. Other means of protection so long as the degree of protection afforded is not
less than that afforded by any of the devices described above.
E. An enclosure shall have all of the following characteristics:
1. Any access gates through the enclosure open away from the swimming pool,
and are self closing with a self-latching device placed no lower than 60 inches
above the ground located on pool side of barrier;
2. A minimum height of 60 inches and maximum height of 72 inches;
3. A maximum vertical clearance from the ground to the bottom of the enclosure
of two inches;
4. Gaps or voids, if any, do not allow passage of a sphere equal to or greater
than four inches in diameter;
5. An outside surface free of protrusions, cavities, or other physical
characteristics that would serve as handholds or foot holds that could enable a
child below the age of five years to climb over.
F. The requirements of this section shall not apply to any of the following:
1. Public swimming pools;
2. Hot tubs or spas with locking safety covers that comply with the American
Society for Testing Materials-Emergency Performance Specification (ASTM-ES
1389) as may be amended from time to time;
3. An apartment complex or any residential setting other than a single-family
home;
4. Any facility regulated by the State Department of Social Services even if the
facility is also used as the private residence of the operator. Pool safety in those
facilities shall be regulated pursuant to regulations adopted therefor by the State
Department of Social Services.
G. Doors, gates, latches, safety pool covers, enclosures, exit alarms or any other safety
device installed to prevent access to a swimming pool from the home, shall be
they are intended.
H. Any person entering into an agreement to building a swimming pool shall give the
consumer notice of the requirements of this section."
