Hi all, I have a 40,000 litre pool. I have a saltwater cell and a sand filter (filter is fairly new, no cracked lateral etc). My water test is perfect. I've slammed the pool, hoping that it might be algae, but it isn't. I've had this dust problem for a while now, and have slammed (properly) twice. Many months later, I even tried an algaecide, didn't help, but at least I knew that it was dust. The dust is too fine, it goes through the skimmer sock and sand filter. I've vacuumed to waste and so I lose a fair bit of water. Swimming in it sucks because once it gets stirred the pool isn't as clear and having the dust go up my nose isn't pleasant. I'm currently using a vet vacuum. Once vacuumed, I let the dirt settle and then put that vacuumed water back in the pool so I don't waste any water. This wet vac system has been the most efficient so far. I tried one of those gel cubes but it didn't improve the filtering, dust still went through filter.
Anyone have this issue? Anyone found a proper solution? A chemical etc? Would DE powder work? In Australia DE is not available, it's banned I heard due to health concerns here.
Would changing the sand to glass fix this?
I don't recall having this issue with a 0.75hp pump, I've used a 1hp pump for the last few seasons.
Cheers
Nick
Cheers
Nick
