- Jun 7, 2017
- 9,062
- Plaster
- Jandy Aquapure 1400
You need to work on that water post haste. Here is some light reading....... Pool School - Trouble Free Pool
Hi I posted more pictures on the previous page if you can share your insight - thanksI cant tell from that one pic. Need multiple of the deck from different angles. Looks like the center sunk amd lifted the leading edge. Whatever cracking is on the deck surface will tell the story better
Thank you - I appreciate that feedback. Basically we had rents in there for 5 years and the pool has been in place this property before we bought it for a total 15+ years.I just want to interrupt this for a minute and warn you about draining a pool in high ground water area like Orlando. You risk the pool floating up like an empty boat if you empty it entirely. Please consider your options- fix the water that is in there, or drain and fill at the same time.
Draining - Further Reading
www.troublefreepool.com
Maddie
In the first picture it looked like chlorine would clear it up. Are you not putting in any chlorine now?Thank you - I appreciate that feedback. Basically we had rents in there for 5 years and the pool has been in place this property before we bought it for a total 15+ years.
I am working to renovate pieces of the house and the pool being one main area but am a novice in all matters. I had a pool cleaning company during the 5 years but apparently they neglected several areas including informing of some issues I'm running into now.
I asked them if they could drain but they said they are not experienced, so was looking to see if someone can drain so we can do some repairs as well. Basically, don't feel comfortable with the water that is in there even with treatment, so inexperienced pool users we are like lets just drain this out - fix - and fill it in with clean slate of water.
