Pool Deck Cleaning
So, we have a Sundek/Kool Deck product on our pool patio. I normally just clean with a pressure washer, but may need to get a bit more cleaning done. What all has everyone used? Anything safe if a little where to get into the pool water? I can probably just spot treat and keep most of it away from the pool, but can be tricky to keep all of the water from dripping into the pool.
Reactions: Ignoramus
I use a pressure washer with this type of attachment. It's safer to the finish and quicker. I use the pressure washer with the 25 degree attachment for touch up. Prior to the pressure washer I used to spray a bleach solution scrub with a tough bristle broom like this. I don't tend to use that as it's easier to me to use the pressure washer with that spinning attachment and I think it gets just about everything.
