Hi all,
I am currently in week 10 of my pool build and I have some concerns about the quality of the job that is being performed. I would like your expert opinions to take a look and let me know if I am being OCD or if my concerns are valid.
I think overall rebar, shell, plumbing and equipment being used is good. The entire pool was even surcharged with the rebar being 12” x 6” O.C.
Where the problem has come into play is with the decking and stone trades.
First issue - Scuppers - Noticed that when the stainless steel scuppers were installed, the copper bonding wire that was nicely placed there for them was not attached. They decided to cut the wire off and not attach it to the built-in clamp on the scupper. Is there any reason why they would not attach it? They have now backfilled the scuppers with concrete. Also, the plumbing on one of the scuppers was not tucked in far enough therefore is it sticking out of the concrete. I can live with that as it is the back of the pool where you can’t see it. Just looks un-professional.
Second issue - Stacked Stone - The stacked stone I selected I guess does not come with corner pieces. Never came to my mind and I was never told that would be an issue. This however has become an issue with how bad it looks. My understanding is the proper way to install it is to miter the corners. Instead they have just been cut flat. There are also random large gaps between the stone that I don’t think should be there. I brought these issue to my pool builders attention and he told me they the tile I selected does not have pre-made corners and that the gaps would be filled with grout. Not the answer I was looking for. They have randomly filled some gaps and I think they look worse.
Third issue - Pillars - Instead of cutting four equal pavers to complete the 24” x 24” top of the pillar they used two 16 X 24 copping pavers and added a small strip in the back to fill the gap. Looks sloppy. The stacked stone on the pillars is crooked. Looks bad when aligned with the water line tile. They tried cutting the bottom stacked stone to compensate.
Fourth issue - Copping is not level. Waterline tile installer held off grouting between coping and glass tile on one side of the pool because the coping was not level and the gap was increasing along the side. Coping guys came out and pulled up and lowered a couple of the pavers but did not fix the entire length. Now it has a nice bow to the grout line. I noticed in our pool contract we paid for a “laser level.” : /
Fifth issue - Space between coping and hot tub trough not equal the entire length. Gradually increases 1 1/2” From one end to the other. Doesn’t sound like much but when there is only supposed to be 3 1/2” overall it is very noticeable.
So, would you guys accept this work or demand it to be fixed? My wife and I have been so stressed about this pool, which we have been saving for over 7 years to build and the experience has not been what we hoped. It was supposed to be completed a few weeks ago, but these finishing trades have been working slow as molasses. I honestly would prefer my pool builder to fire these guys and bring in someone else as I feel they are terrible at their job.
Thank You
Thank You
