After a lot of experimentation, I finally found a solution that keeps my Nautilus CC Pro cleaner from getting stuck on the main drain. Get a 5820 Polaris Unibridge and then alter it as follows:
I cut the center out with a jigsaw through the middle of the 3 central slits. I then used a power sander to sand down the top portion until the last slit was paper-thin. I then used a knife to slice through the middle of the spokes on that last thin ring and folded those pieces downward. I taped a squeegee to my pool brush pole to check to make sure the main drain wasn't protruding up beyond that hole. My CC Pro no longer gets stuck on the main drain, and the Polaris Unibridge stays put
