- May 3, 2021
- 47
- Vinyl
- Jandy Aquapure 700
I have a question about bonding an in ground pool. We just had our existing old concrete pool deck ripped out and realized it wasn’t properly bonded. I’ve run a 6 gauge copper wire around the whole pool and attached to multiple pieces of Rebar in the wall as well as the pool light. My question is does the wire need to be buried in the dirt a little bit or sitting on top so that it will be incased in the new concrete? It’s 6 gauge so it’s thick and doesn’t lay flat everywhere and kind of hovers above the dirt in areas but will be fully engulfed once concrete is poured. Just want to make sure the wire is touching what it needs to be touching, concrete, dirt or both??
