Pool app suggestion
Bvacchiano
429
Sugar Land, Texas
Why can’t you add the other affects to the main page? For instance when I go to CYA application why can’t you state here the “ph will decrease by x amount”. Why do I need to go to the “effects of adding “ to see this? Just include it on the main page. Also when go to PH list the effect to TA,etc. I don’t see the point of not having that all on the front page.
We’ve tossed the idea around a few times and likely will revisit the idea again this Winter. We very likely won’t allow the chemical additions alter the actual test numbers but we may add recent additions for a quick FYI. In all honesty the main reason is how should we display this info cleanly on small displays without causing the page to really start to drag all on and on.
