Closing the pool and tested pH and Chlorine last night. pH was 7.5 to 7.6, and chlorine was a bit high at 7.5. Put 1 qt of "pool solutions algae prevent 60" in this morning and ran the pump to let it mix for a couple hours. Pulled the return Jets and thought I would check the levels again just to be sure before I shut down the pump. I was shocked to see the pH was ~8. Does polyquat increase pH that much? My TA has been holding steady around 90.
Levels
FC 8
pH 7.8-8.2
TA 90
CH 150
I've never checked levels after adding polyquat so I'm not sure if this is normal. Should I lower pH? don't really want to leave my pool around pH 8 until April 2018.
Thanks
Levels
FC 8
pH 7.8-8.2
TA 90
CH 150
Thanks
