All,
I am about to take the plunge and purchase a polymer pool with a salt water generator. I live south of Buffalo NY where winters can be harsh. Most of the information I've seen suggests a galvanized steel wall pool with an SWG is a bad idea. However I'm also somewhat fearful of frost heaves that can crack polymer. Is there any real reason to be concerned?. Two pool builders who have built both types recommend steel and two others recommended polymer. The steel guys say the corrosion concerns are overblown and that repairing surface rust is much easier than a cracked polymer wall. If I'm getting a new liner every ten years, I can address any rust during s changeout. Should I reconsider steel as a solution or stick with polymer. I'm also planning on 48" walls if that makes any difference.
