Polaris P825 Problem
Sammie85
1
Louisiana
HELP!!!
Today my robotic cleaner stopped working so I started troubleshooting it. Cleaned basket, took cover off the propeller and cleaned. I have discovered the the propeller won’t completely startup. It will start spinning then stop and it continues this for about 30 seconds until the information light starts blinking. Help me please. I’m having the worst luck with the pool right now. I’m currently waiting on a new motor so my poor robotic cleaner is the only thing keeping my pool from completely going green by moving the water at least a little. TIA
Hi
I have a P935 that has something similar. Most likely the motor housing o ring has failed and water is in motor housing. If you are quick in opening the housing, you may be able to save the electronics from shorting completely. Open it up, dry out everything (use electronid cleaner) and then test the motor. If it runs, youre in luck, otherwise needs a new motor housing. Almost $500 (canadian) where i am.
