This weekend I'm replacing a 20 year old pump with a new Hayward. There's a ground wire running from the pump to an old Polaris booster I'm no longer using.
Question is- does this plan make sense?
Disconnect ground wire.
Cut Polaris tube out of return line and fill with coupling.
Detach Polaris tube from return pipe and cap 1 1/2 in pipe.
Attached picture hopefully explains all.
Next question- there is a return for the Polaris which currently has an eyeball. Any issues keeping eyeball (unused) there till I close the pool?
Auction is on far left and return is on right if I have it right?
