Hello TFP experts - having a rather strange problem. I have a Polaris 380 that has been working great all these years I've had it. I'd rebuilt most of the insides last summer and haven't had any problems since then. About 3 weeks ago, I decided to replace the leaky old school booster pump hose connectors (white + red strap PVC? fittings) with the black quick connects (Amazon.com : Polaris Pool Black Softube Quick Connect Booster Pump Fitting, 4-Pack | R0621000 : Garden & Outdoor). When I turned on the booster pump after I put in the new connectors, I thought everything was fine (at least I didn't notice that the 380 wasn't moving normally). Later that evening, I realized there was a slightly loose connector with a small leak, so I fixed it and that's when I noticed the 380 was barely moving as it used to.
Today I finally took it out and looked inside. The feed pipe o-ring was all stretched out - so I replaced that. Everything else looks great - the belts, the turbine, the water management system etc. (everything is new since I rebuilt it just last summer new bearings, wheels, tires etc.). The 380 is still not moving as it used it.
So, my question for the experts: could this be because the pressure coming into the 380 is higher than it was (since there are no more leaks around the booster pump hoses anymore)? In other words, should I check the wall quick disconnect to reduce the pressure? Or is there something else more subtle that may be going on?
Appreciate any help. Thanks!
