- May 26, 2020
- 154
- Plaster
- Pentair Intellichlor IC-40
I'm looking at this FC/CYA chart here:
www.troublefreepool.com
It says for my CYA of 80, I need a minimum of 6 FC, with an idea range of 9 to 11.
However, in the Pool Math iOS app, it shows the recommended range is 4 to 11 FC.
I'm making a guess that the chart is correct, and I should use the 6 minimum, but ideally should be in the 9 to 11 range, rather than 4 to 11?
CYA Chlorine Relationship - Further Reading
