Plumping challanges
csconner
121
Coopersburg, PA
Would value input/suggestions to improve this part of my pad plumbing.
I was considering reconfiguring coming out of HP.
I want a bypass to bypass HP, only way I can see is to insert 3 way valve to match a new three way in back between pump/HP, move/turn sacrificial anode to the left, 90 into SWC, 90 back to input to the manifold.
What are thoughts on the flex? PB did the flex to make it easier to compensate for the wonky angles of the pipe up to back of pad.
Pool returns are on left, water fall is center, Skimmer Venturi is on right, hence manual valve as I never turn that off.
I’ll draw up a diagram and post to give better understanding for all.
I would mount the SWG vertical which then gives you plenty of room on the heater output for a check valve, a T for the heater bypass, the anode, etc.
The flex will not last as long and be a problem someday. Deal with it then.
