I'm running 2" return and supply lines (PVC) from my equipment pad ,
Pentair Pool Products PNCC0150OP2160 Clean & Clean 150 Sq. Ft. Cartridge Filter, to my 12 x 24 Intex Pool. The connection to the pump is 1-1/2". How long should the transition from 2" to 1-1/2" be at the pump to avoid any flow problems? I will run 2" to the three-way valves at the pool and 1-1/2 " from the three-way valves to the pool connections.
Thank you....
Thank you....
