Hello,
I have a few issues with my plumbing that I would appreciate some advice on.
1) When my pool or spa heat reaches the desired level, the computer controlled valve switches from 'gas' to 'solar.' This causes the water to go up onto my roof, traverse through the solar, then come back down and go through the gas furnace (which is now off), then back into the pool or spa. This is extremely inefficient, usually resulting in an actual cooling of the water (or even draining of the water as my solar panels are leaky). This is especially troublesome when heating the spa on a cold night... The temp gets to 104F, then the valve switches and the water runs through cold pipes, quickly cooling the spa resulting in a heating/cooling loop that burns extra gas. Obviously what I would like is for the gas to switch off when the temp reaches the desired level, but for the filtering to continue going directly through the furnace rather than up onto the roof.
2) I would like to be able to program the pool to heat between certain hours and the spa to heat at other hours and have the computer switch the plumbing accordingly without manual intervention. I'm sure this will take new hardware, but I'm not sure exactly what.
I've included a photo with labels of my current system which has 4 manual valves and 1 automatic valve (plus a backwash/drain valve). Thanks in advance for any advice!
