I just moved into a home and am swapping out the pump, however, it sits about an inch higher than the main line. It's on a concrete pad. Is my only option to cut the pipes (which means replacing the valves) to make it level? Pictures attached.
I used the 2 x 22.5 and it leveled it up! Thanks! Now to tackle the valve end...You might be able to use 22.5 degree fittings.
You can use (2) 2.5" fittings in socket or one in socket and one with a spigot side. and then a bushing.
2-1/2" Sch 40 PVC 22-1/2 Street Elbow - Spig x Soc 442-025F
Save and order this 2-1/2" Sch 40 PVC 22-1/2 Street Elbow - Spig x Soc 442-025F from PVC Fittings Online! We ship directly to you.www.pvcfittingsonline.com
2-1/2" Sch 40 PVC 22-1/2 Elbow Soc 416-025
High quality 2-1/2" Sch 40 PVC 22-1/2 Elbow Soc 416-025 in stock now at PVC Fittings Online! Low prices and speedy shipping.www.pvcfittingsonline.com
2" Sch 40 PVC 22-1/2 Elbow Soc 465-020
In stock now - 2" Sch 40 PVC 22-1/2 Elbow Soc 465-020. Order from PVC Fittings Online and save!www.pvcfittingsonline.com
Gotcha! I wasn't aware of the difference! Thanks! I have glued anything yet so I will swap them out.The outside of the valve will take a 2.5" socket over the valve.
Make sure that you are using schedule 40 deep socket and not DWV shallow socket fittings.
The 22.5 degree fittings at Home Depot and Lowes are likely to be DWV, which are not pressure rated.
The sockets should be at least 1.25" deep.
