I am looking to upgrade my 1hp single speed. I am thinking of jumping to the Calimar 3HP, which could be overkill but I have a lot of pipe length and elevation change so better be safe than sorry. Given the price, its a no-brainer. Yes, this pump might be Crud but I am ok taking the chance on it. Onto the topic of plumbing, see attached picture. Ignore my unfinished landscaping!
The un-valved inlet is my skimmer, the valved inlet is the main drains in the deep end.
The red on/off valve at my outlet is the returns, the black valve feeds a waterfall, bubblers, or both depending on the position of the valve. Prefer not to touch these, this setup works for me.
1) First, I would be curious for input on how my installer did, and if there is anything I should generally change while I am installing the pump. I have done a lot of pvc plumbing, so reworking this would be easy for me (man's last words).
2) Given I have no union on the pump inlet, and the fittings stack against each other, I will have to cut back to the elbows coming out of the ground. I've got enough horizontal PVC just after those elbows. I am not sure there is an easy way to salvage anything. So, start fresh just after elbows - Agree with this approach? Any benefit to a Wye + 45 elbow vs a 90 elbow where the main drain and skimmer merge? overthinking it?
3) I plan on using these unions directly on the pump: Amazon.com Good option? Given the O-rings, do people skip teflon tape / thread sealant?
4) Any suggestion on how to handle the pump outlet? There is a union after the turn, I am not sure if these are standard and I can buy another union and re-use the half that remains on my piping? This would be easiest. If not, same scanario as the inlet, I just have to replumb everything up to the filter.
5) Any recommendations on where I could add a clamp-on style flow meter? I don't have a lot of straight runs in my piping. How critical is it that I have one? Seems like a nice-to-have with a VSP.
Thanks in advance, lots of questions there I know....
