- Aug 19, 2021
- 1,603
- Plaster
- Pentair Intellichlor IC-40
I want to reconfigure deck jets so that they are supplied off of the water feature pump instead of the circulation pump. This is the way it was suppose to be plumbed initially but was not. Doing so will enable me to run the spa spillover/deck jets/waterfall/water slide simultaneously if desired. I have already remove the jandy valve from the circulation pump side that fed the deck jets now I'm trying to determine the best way to add it to the feature pump. I do not anticipate a desire to use the deck jets and not the waterfall but definitely want to be able to use the waterfall and not the deck jets.
0ption 1. I put the jandy 3 way and actuator in place of the 2.5 90 here. This would require some strategic removal of the elbow or replacement of everything after it.
Option 2. Add a 2.5 tee below that 90, then a jandy 2 way with actuator . This could be done without replacing the check valve and pump union
Option 3. Open to suggestions
