please help me with my numbers
The chlorine was below 10 when you tested PH at 7.8 so it is a good number. Enter your pool gallons in PoolMath, enter your TA number in now and target and enter PH now 7.8 and target 7.2. Add the amount of acid it says to add. Make sure you have the correct acid percentage for what you have.
The PH test is not valid when chlorine is above 10.
Good morning! Well I kept checking until 900 and FC was 16.5 at that time CC0
In the morning it was 15.5 and CC0 FC went down to 15 at 1000 and is 13.5 (the sun came out) at 1200 CC has stayed at 0
So can safely assume pool is clear I can let the chlorine drift to normal levels and then check my ph, cya and ta? Or should I keep the chlorine at 12 or so for the day and let it drift over the night and day to normal levels?
