Plaster stain removal over winter?
TurboMatt
23
Frederick Maryland
I have been working on removing stains on my plaster pool walls and floor all summer. Lots of brushing and have kept the FC above normal, around 6-10ppm. The stains have softened up some but I was hoping they would be gone by the time I had to close the pool. My plans are to close the pool in the next 2-3 weeks.
Short of draining the pool and acid washing it next spring, do I really have any options? I've scrubbed and scrubbed with a stainless plaster brush. I have verified that they are organic stains by scraping a chlorine tablet on them then waiting some time to see the stain mostly disappear.
I have read that lowering PH is very helpful to kill the organic stains. Figured this may be a good option since there will be no more swimming.
Any ideas?
Thanks
Acid and/or power washing may be a quick/efficient method, but may not be feasible if your water is elevated. Something to be careful about. You mention the FC being 6-10, but I wonder if that is really a strong enough FC/CYA ratio compared to your current stabilizer level?
I have the same issue. I have power washed and acid washed but still there are stains. My plaster is well bonded and nice and thick so no leaks but I would hate to have to have it replasterd. Thinking of putting plaster on top of the existing plaster. Maybe first sanding the plaster to give it a texture and then rolling of some stuff like cider-crete or mixing it my self.
You can add ascorbic acid - that will lower the pH (high 6s/low7s) and chelate metals causing stains. Not sure I would want to leave that water in contact with the plaster all winter, though.
Have you done the chlorine puck/ascorbic acid test first to identify the stains?
