Plaster in PVC pipe - ideas to remove
Scott-Texas
2
Texas
Following a plaster job, I was left with a plaster blockage in the bottom of the spa drain pipe. Looking for ideas on how to remove. It is where the two drains meet and then form a tee, leading back to the pump. It is hard to get at as it is about 1 foot in from the drain basket, and then at 90 degrees where the second pipe carries water away. I used a small camera in the pipe to take a picture. Acid has not worked. Scraping it with a metal hook has not worked. It is pretty solid and attached to the PVC (I.e. not a chunk that's just stuck). Running out of ideas. Thanks!
