Opened pool (company) 2 weeks ago. All was fine, did my best to maintain some FC and pH over the winter. It's a one year old concrete/plaster pool. Last year had no issues other than pH drift up, which I read was due to new plaster and SWG. Would add a bit of acid regularly, and it would go down.
On opening, all that was needed was some water and salt.
Pulled my polaris the other day and saw some granular stuff in the bag. I thought it was salt that hadn't dissolved. Pulled it again, and found out that it's not salt. Feels like fine sand. Clearish white in color. I felt the sides of my pool and they feel like sandpaper, but it brushs off pretty easily. its all over- not just in one spot. Opener didn't notice it and neither did I at the time.
The granules are way too uniform to be scale in my rookie opinion, each seems to be perfectly sized. Chemistry is good- CH 290, pH 7.5, CYA 40, FC 5, TA 90. Same numbers I ran with last year and had no issues. I am guessing it's from over the winter, it doesn't seem to be high on the sides, below where the water level was seems more affected.
i think my plaster is dissolving( or dissolved), but why? Again, can't be low pH or CH issues? Unless I had one over the winter without knowing. But I checked it pretty regularly. At least once a month.
thanks
thanks
