Hey team!
I've got an ~18,000 gal pool in-ground gunite/plaster built in 2020. It has a salt water chlorine generator do pretty well with the with water chemistry, tho I admit to being a little lazy with the muriatic acid, so my pH is commonly around 8.0. I've seen very localized deposits of scale accumulation on the side walls this last summer, but with a fingernail and staying ontop of the acid, it went away.
My problem is in seeing areas of light brown plaster discoloration on the bottom of the pool. It doesn't seem to scrub out, and it is not texturally different like the areas of scale. It doesn't look too bad, but I wanted to get ahead of it and fix it if I can.
I live in Wilmingon,NC and the pool is not heated.
Here are a couple pictures, hopefully you can see what I mean.
Thanks for any advice in advance!
-Sully
-Sully
