Hello all!
I am new to the forum. A little background: for the past 14 years I have gone to a local private pool to do aquajogging. I wear the aquajogger belt and run for about 30 minutes suspended in the water without my feet touching the bottom and do some other exercises. I'm 5'6" tall. Well, the local private pool closed and now I have limited options-and our community pool's hours arent good. So husband and I have decided to build our own pool. We are in the research and planning phase.
We need something the size of a swim spa, but small deep fiberglass pools are hard to find. I like the water to be above my shoulders when I'm jogging. We looked at the Hydrozone pools by Viking but the deepest is 5'. I don't know if anyone has one or something of a similar size that is at least 5'6" deep. We got a quote from a builder who would build us a 10x20x 5/12-6' cement block coated with fiberglass pool, do the electical gas & decking, & it came out just shy of $60,000. And we are looking at a Swimex Triton swimspa custom depth of 66". Which would be about $40,000. I'd like to get a heat pump for heating and install solar to help offset the cost of the electrical associated with the pool no matter what we do. I saw that Pentair has a heat pump/gas heater hybrid heater that is expensive but would likely be worth it. I'd like to keep the pool temperature around 90 degrees for exercise. We are planning to enclose the pool or swimspa as well, either with a steel building or building an poolhouse. I want it to be indoors so I can use it year round.
What are thoughts about pool versus swim spa? Experience with concrete block coated with fiberglass?
PPierce2nm
PPierce2nm
