like the title says,
The pool was built in 2007 and I have made some upgrades since then, most notably a 2.7hp VS Jandy VSFloPro, and I converted my Aqualink RS (the one with the PDA) to an iAqualink 2.0 which is control thru the iaqualink app. The VS Pump is controlled by the controller and does not required the manual keypad that some pumps come with.
I would love to have a similar setup with a SWG that integrate with my current controller, I have seen somewhere in the setting an options for an aquapure setup sometime ago. my pool is about 15K Gallons, located in Central Florida. if possible I would like a SWG that could run with very minimum salt in the water . Not sure if this makes any difference but the pool is screened with an enclosure and is not heavily used.
What salt cell do you guys recommend? trying to avoid having to have a separate controller and would love for the install to be DIY friendly. Thank You
