Planning to place my pool equipment order with SCP Distributors this Friday for my Owner PB and think I've got everything nailed down with 1 exception and could use some clarification/understanding/guidance.
Details of pool/spa combo in my signature but will be a 17K IG with elevated spa with spillover. But my question surrounds the 3 Water Descents that we would be adding on some raised beams. 2 descents would be 2' (sitting 10" above coping) and 1 descent would be 3' (sitting 16" above coping). The only other water feature I would have are 3 bubblers in a tanning shelf but I believe those would be fine to run through the Pentair Intelliflo VSP (3HP) I've chosen. So that leaves me with those 3 descents and what thoughts folks had on dedicated pump for this? Or is dedicated necessary? And if a dedicated pump is installed, (newbie question) but where does the suction for that occur? I've looked at some plumbing configurations and while I see a defined suction section, in the setups I've looked at the water features sections seem to be separate from the suction area at the equipment pad, so I get confused.
Any info that can be shared would be appreciated. I through in a screenshot of a video I took of a friends configuration which is what partly led to my confusion. He has 4 water descents which I can correlate to the right side with the never lube valves, and I can see its attached to a dedicated pump, but the inlet side for that pump there is a just a single line that goes right underground. Is it possible that underneath it is connected to the rest of the suction? Does the water feature pump not run through the filter?
