Three times this winter we've had a rapid loss of Chlorine as measured by the Taylor DPD kit. We maintain our pool to TFP standards. Mostly we have sparkling water, but ...
On Tuesday and for the past few weeks, our water has been sparkling and clear. (Very light bather load lately.) Here was the measured chemistry:
FC: 6.5
CC: 0
pH: 7.5 (looked between 7.4 and 7.6)
TA: 60
CH: 350
CYA: 70
Salt: 3800
Borate: 0
Temp: 84
Today, Thursday, the pool was ever so slightly cloudy,
FC: 3.0
pH: 7.6
all others as above.
SWG is 22.4 oz per day, SWG running at 50% for 10 hours, so adding 2ppm/day to our 17250 gallon pool. Pool inside a screen enclosure.
I've had the CYA double checked and we and our pool care get the same reading. Each time, we've had the problem, I've properly SLAMed the pool (brushed extensively, cleaned the filter, measured overnight Cl loss) and that seems to settle it until the next drop.
When we were dealing with a slight discoloration issue on the plaster finish, Haviland measured the water chemistry and found 10,600ppb phosphates in the pool and 260ppm in the autofill source water. My pool care guy who seems very good wants to treat the phosphates, says it's a problem here in Naples FL. (I know the TFP view on phosphates vs algae in the water.)
Is it possible that I need to keep FC in the 8-10 range as with a non-SWG pool? I'm wondering that because Cl usage seems to be 1.5-1.75 ppm per day until I hit 6-7 ppm.
FC: 6.5
CC: 0
TA: 60
CH: 350
CYA: 70
Salt: 3800
Borate: 0
Temp: 84
FC: 3.0
pH: 7.6
