I think the pictures tell most of the story ... see attachments. I'm seeing phantom equipment and aux on my Jandy PDA system. Also, "VSP2 SPD ADJ" is always "on" but I never programmed it. When I scroll to VSP2 I can't seem to make any changes to it.
My system has an ePump, SWG, and solar. The system is running fine except for the obvious odd display and my pump (programmed for VSP1) no longer runs at the set speeds - I have it programmed to run at a high speed for several hours and then a lower speed for several more hours. Based on the above it looks like VSP2 is controlling the pump.
Any ideas on what is causing this or what I can do to get it back to normal. I did try "clear memory" on the PDA but that didn't change the behavior.
David
David
