Maybe a dumb question, maybe not. I do the Taylor drop test for my PH in the small tester that does both PH and Chlorine.
My question is, after adding the 5 drops, do you simply invert the container a couple times or shake to mix? Simple invert, my PH is high, shake to mix, PH is around 7.6-7.8.
