PH test, do I need my eyes adjusted?
rajung
470
Cedar Falls, Iowa
Something I have wondered about for some time.
When doing the PH test my level always is between 7.6 and 7.8.
But I noticed if I turn the "test box" ? horizontal with cap on, the colors will be slightly off?
If its 7.6 it may show 7.8 and vise a versa. yes, I must be bored .
Those colors can play tricks on my eyes as well. :crazy: I have the most difficulty between 7.4-7.4. But when the occasion comes along I have to lower my pH to the low 7s, making it orange helps give my eyes a good reference and something easy to compare to. I also found that experimenting with different backgrounds has helped.
I have to ask my kids. It seems 7.8 - 8.0 is hard for me to tell. It’s may be an age thing. They take one glance and tell me right off.
That's a cool trick. I'll try it.
Here's what I do: Bring the test cell right up to my eye, letting my vision "blur". I hold a white card several inches behind this with the other hand, tilting it to light it well. I look through the test cell at the white card (everything's blurry), then rapidly slide over to the color comparison slats. A few "flashes" back and forth and I can pretty easily figure out pretty precisely where the test water falls compared to the color slats. Bringing the cell close to the eye removes external stimulus that can alter color perception. At this close range, the color almost completely fills the field of view, and minor differences in color are pretty easy to see when you "flash" back and forth.
This works for the chlorine (OTO) test as well, assuming your CL target is low enough to work.
Be careful; ensure you don't spill or splash reagent and test water into your eye. I've never come even remotely close to doing so, but it's a valid concern.
