I remember reading about the higher FC levels promoted by TFP making the typical color tests for FC inaccurate, as the reagents can bleach out. So, we have the drop test, which works great.
But can the same happen with pH test reagents?
I'm trying to lower my Total Alkalinity, and of course the recommendation is to lower pH with muriatic acid, which will also drag down TA, then aerate to bring pH back up. But ever since starting to run higher FC levels, my digital pH meter and my Taylor test kits disagree. The meter recently underwent 3-point calibration, which should give it accuracy near ±0.01, but I'm not sure I trust it. I've always favored the Taylor test kit accuracy.
Right now, I'm at 7.4 on the Taylor kit vs. 7.81 on the digital meter. Neither is a problem, but the 7.4 already has me at CSI = -0.48, so I want to be sure I'm getting reasonably accurate pH readings before dragging it down farther to the recommended pH = 7.2.
