PH Spike - Auto Cover to Blame?
JasonAnt
14
Chicago Suburbs
Fiberglass
Hayward Aqua Rite Pro (T-15)
Happy Independence Day!!!
The water chemistry on our in-ground 14,500 gallon pool has been very stable this year. Twice this year, however, the PH has spiked from a normal reading (7.5-7.8) to around 8.1-8.2.
This is our second season of pool ownership, so I'm still learning.
I can only think of two things at play here:
  1. Our pool company installed a Hayward Sense and Dispense unit this spring in order to control our SWG. The ORP readings seem to swing all over the place at times, regardless of the FC readings. It seems like our SWG has run-away at times due to low ORP readings. This seemed to be the case yesterday when our FC spiked to 21.0 and the PH spiked to 8.1 from a previous reading of 7.5. Can high FC cause a spike in PH? I haven't been able to find this anywhere in a search of the forums.
  2. We do have an auto-cover. The pool has been covered for about 2 weeks due to some perpetual rain storms we've had here in the Chicago area. Is it possible leaving the pool covered would have an impact on PH? Again, I couldn't find anything in the forums search I performed.
Test Results 13 days ago:
FC 3.5
CC 0.5
PH 7.4
TA 80
CYA 55
Salt 4000
Thanks for your help.
Jason
Jason, it's not the cover. The additional work from the SWG can create more aeration which can increase the pH. In addition, once your FC increases to over 10, it influences the pH level making it look higher as well until it settles again. That's a big reason here at TFP when we have owners start a SLAM to remove algae, we have them lower the pH first before increasing the FC because after the FC is over 10 the pH test isn't valid.
As Pat pointed out, above FC of 10ppm, the phenol red pH-test will always show high.
But your pH will actually really be high. One reason Pat already explained, additional aeration.
But the creation of chlorine with an SWG by itself actually also increases pH. Usually, you don't notice that, because the use of chlorine for killing germs and things reduces pH again. So, as long as you are producing as much chlorine per day as you are using (i.e. FC remains constant), the chlorination cycle is pH-neutral, and only the pH-rise due to aeration will be noticed.
But when overproducing chlorine, pH will also rise. That rise will be compensated again when FC drops back down to the original level. But while FC is elevated, pH will also be elevated.
Thanks guys.
The ORP readings on my Sense and Dispense seem unreliable... or at a minimum, don't correlate to my FC readings. I think I'm going to switch back to a schedule/percentage for my SWG.
Reactions: mgtfp
