pH rising in gunite pool after 1.5 years
dphanes
152
NC
Our Gunite pool was finished in November 2020. It’s 26,000 gallons. Salt water system. Since it was finished my pH always tends to rise. About every two or three days the pH will get up to around 8.0 that’s as high of reading as I can get with my test kit. And I put in about half a gallon of muriatic acid and it drops it to about 7.3. I thought that the cycle would stop after about a year from what I had read. Really struggling with why the cycle continues. Does a salt system result in a rising pH? Is calcium somehow leaking out of the cement in plaster which I can imagine is a good thing? Any help would be greatly appreciated
You can let your TA go as low as 50. Why don't you manage pH for now to get TA down. Try to just keep it above 50 for a while. Lower TA levels will help reduce pH rise. Also, let your pH rise to 7.8 or 8.0. You might even let it go to 8.2. Let's let the TA go down and sit 50-60 and your pH sit at 7.8, 8.0 to 8.2. My guess is that you will find an equilibrium in there somewhere that will slow pH rise.
Deeper reading if you are interested:
I will try it. Thanks
Reactions: PoolStored
