- Dec 13, 2018
- 443
- Vinyl
- Pentair Intellichlor IC-60
In the past, I have had a new build gunite pool with plaster finish and SWG. As expected, my pH was always on the rise and I controlled with muriatic acid.
Now my pool is vinyl with a SWG. I have jugs of MA anticipating the pH rise, but it just is not rising. It just stays at 7.8 all the time (although today it was 7.6, either due to rain or the fact I did the test in natural light. Usually I test inside early morning prior to sunrise). I have a sheer descent waterfall also, but I do not run it very often, maybe a couple times a week.
So what gives? I was expecting the SWG to increase the pH as it is supposed to do.
Is my TA right in a perfect balance not to cause a rise? My other thought is that my FC may be high possibly bleaching out the pH test.
I'm not unhappy with the results, just baffled.
Thanks.
FC = 9
ph = 7.6
TA = 60
CH = 110
CYA = 60
SALT = 3600
TEMP = 86.4
CSI = -.081
Thanks.
FC = 9
ph = 7.6
TA = 60
CH = 110
CYA = 60
SALT = 3600
TEMP = 86.4
CSI = -.081
