I purchased the pH meter from TFTestKits.net, and am pleased with its performance so far. A couple of questions for anyone who’s used it:
1) How often does it need to be calibrated in the future? The instructions leave something to be desired: “whenever. [sic] The electrode has been used(laid) for long time.”
2) Do you need the two (or all three?) solutions during recalibration, or is the 7.2 solution from TFTK’s sufficient? Another thread (and TFTK itself) mentioned using just the standard solution, but I’m wondering about the need for a second buffer when initially calibrating. Which brings me to:
3) When using more than one buffer, after adjusting the pH reading and placing it in the second buffer, if the reading is off do you re-trim the probe again? Or is the second buffer just a check? Again, the instructions are (amusingly) vague: “After about one minute, until the buffer solution value corresponding to the measurement temperature is obtained.”
Thanks all!
Thanks all!
