I have a 40,000 gallon pool. I also own the Taylor K 2005. Yesterday I did the testing, assessed it was an 8.0 pH per the color. Plugged in the alkalinity at 140 after using the Taylor. It recommended i add a gallon and three cups of muriatric acid 31.45% to lower pH to 7.2. I added a gallon. Today, about 20 hours later. Pump running 100% of the time. Skimmers emptied. I do the test. Alkalinity is 125. pH still the same. Even same number of drops, 4 drops until color changed from red to yellowish. What can be going?
