I attach 2 photos from the device I have had installed which automatically measures Chlorine and pH levels and injects muriatic acid and liquid coloring as required.
The chlorine levels stay nice and even but the pH levels are cycling as shown in its monthly view.
The supplier of the device has no logical explanation for this behavior in the pool water pH.
I have my concerns about the rather wide level fluctuations and also have theorized to the device supplier’s team (this company invented the device so their engineers have also loooked at this. They had a replacement motherboard sent out to be installed by their tech, with a couple of key fixes and upgrades in the new board.
I wonder if this cycle represents the natural cycle of water pH for some reason (does not seem related to our rain patterns here in the DFW Metroplex) or possibly the device having trouble keeping the pH within its upper and lower limits.
They come out about once a month to replenish the chemicals, check the water chemistry and rebalance manually if needed. One time the tech made an error and over-added acid but that was when the old board was giving inaccurate readings.
My TFT tests mirror what the sensors reflect whenever I test the water, so now it’s down to either some underlying residual issue with the pH part of this system, or a cycle of pH like this from something happening in the water or the plaster surface which I cannot “see”.
Any thoughts? Thanks in advance.
