I can't figure out why my pH keeps drifting down. It tends to stabilize at 7.2 or 7.3. According to the pool calculator my pH goal should be 7.5 to 7.8 but I just can't seem to get it to stay there. I was adding Borax every other day and then I finally gave up and decided to see what would happen if I just stopped the steady diet of Borax. The pH drops to 7.2 and stays there.
Maybe this is a non-issue. My water is crystal clear. I try to keep my FC at 7.0, towards the high end of the recommended 4-8 range based on my CYA 50 level.
What do you experts think? Could it be related to aeration, or lack of? I'm the only one who uses the pool and I don't splash around much. Usually I'm just dunking in to cool off, or floating on a raft. Is it something to do with my chlorine level? Am I worried about nothing?
Here are my readings (TF-100 kit). Thanks.
pH 7.2
FC 6.5
CC 0.0
TC 6.5
TA 80
CH 20
CYA 50
pH 7.2
FC 6.5
CC 0.0
TC 6.5
TA 80
CH 20
CYA 50
